Just bought new 2013 TE449... Coolant issue at 30miles and need feeedback
gtxscirocco
Hey everyone,
I just bought a TE449.
So Today I put 30 miles on her between road and trails.. When I got home I turned her off and then a squirt of coolant came out of the overflow hose. (Just shot right out the very moment I turned the bike off)
Whats this about?
It's possible they over-filled the coolant in your radiator. When cold the coolant level should be below the neck of the radiator but covering the top of the inner fins. If that's good and the problem persists you could have issues with the cap maybe. Or a thermostat if that bike has one.
Yep, check level, see if the fan is coming on. Mine won't unless I go really slow or,idle for a while.
Change the oil often.
My automatic fan never worked so I put it on a switch. I put a 2 bar cap on after I replaced it once with a 1.8 stock. I don't run the fan all the time and have boiled it since. Thinking of changing to the evans coolant. Its the slow stuff that gets it too hot!
+1 on the XF coolant. My fan has always came on as it should, but I am going to install another fan on the other radiator.
These bike do get hot in the slow going. I have not boiled over since the XF coolant from zipty. On fast trails and on the
Road it never gets hot enough for the fan to come on...
