Hello friends,
This is my first post and my first Husqvarna bike.
I just purchased a 2011 TXC 250 on eBay and love the bike.
Everything mechanically is pretty much stock, except an aftermarket radiator fan and headlight (both are wired to turn on together at the same time), a FMF silencer...The Trail Tech dual headlight only has one light working right now, but I haven't checked the bulb or wiring yet for the headlight yet... will look into that.
Previous owner took great care of the bike and just had the top end rebuilt (new piston, rings and cylinder) and installed a new fuel pump, stator, voltage regulator, and battery. Bike has been running great and the clutch drag/difficulty getting into neutral has seemed to be disappearing as the new engine has been getting broken in.
However, I need help installing the Speedo that came with the bike... I believe it is from a te250. I have the wiring hardness that hooks up the speedo, but have no idea how to hook it up to the existing wiring system (and don't want to mess anything up, as the bike is running great right now).
I need to make the bike street legal in Massachusetts, USA (which I plan to do with a Tusk enduro lighting kit for the turn signals and brake light), but not sure how to proceed with the Speedo. It seems to be a plug and play situation, but not sure how it connects to bike as it currently sits. The TXC didn't come from the factory with a street legal kit. Any info or advice would be greatly appreciated. I will attach some pics of the bike and speedo/wiring harness.
Main question is basically: Can I easily hook up the Speedo and wiring hardness (for the speedo) to a stock TXC? Or will it take some customization to work properly?
Thanks!
Thanks!
