MotoSteve
I need some help with diagnosing and possibly re-jetting my bike.
I have a 2006 TE610 with a LeoVince X3 slip-on, no air-box mods. I live at sea level(coastal CA) and ride primarily from sea level to below 2,000 feet. The previous owner stated the exhaust was installed and jetted at motoexotica in Vacaville (I know they are a knowledgeable dealer and I only include this for atmospheric reference as Vacaville is only 200 feet above sea level).
1) I am experiencing excessive backfire/popping on fully-closed-throttle deceleration. Not just a few pops; the bike backfires rapidly until I give it partial throttle or pull in the clutch and relieve the engine braking.
2) There also seems to be a momentary lag in acceleration when I quickly go to full throttle, then after a moment and a few more rpm the power comes in again and builds as normal. That lag in acceleration is more noticeable now that I have installed a set of SM wheels/street rubber as the back tire is not spinning in the dirt. A local motorcycle mechanic suggested the power lag may be due to the fuel pump not keeping up with the throttle and an O-ring should be placed on the fuel pump to fix this(I’m guessing like a rubber band to help it open faster, but I’m not fully sure what he’s talking about)? I figure I’ll start by sorting the machine gun backfire then see about the flat spot.
Can anyone tell me what jet sizes and position I should be running to eliminate this continuous popping on deceleration?
Thank you in advance.
