Jd Tuner Settings Te250 2010
Freaky
I installed my new JD tuner on Saturday, I left all the settings as they came pre-programmed for my bike and raced it Sunday to see what difference it has made before I start changing things. The mid range power has improved quite significantly, it pulls stronger and smoothed out the top end hit, feels much more controllable and faster.
I am still stuck with the stalling issue which is the one and only annoying point about this bike, Sundays race was difficult and had many slow areas where the bike just dies on low revs, I have to feather the clutch constantly and keep the revs uncomfortably high to try and avoid a stall, I have a 12t front sprocket, will the JD tuner fix this issue? What settings should I change?
I have read various threads on the 12 port injector and a new ECU but I really can't spend that kind of money at the moment.
Thanks
Trevor.
I have a different injector and no ECU and have generally leaned out green and green/ blue and increased the accelerator pump feature. So far this has worked well for me.
What injector have you got Jason? Is yours a 2010 TE250 too?
Trevor.
Thanks chaps, I will have a play with the low end settings on Saturday, racing again Sunday so will test it out again.
