Inlet Manifold
RTM
The inlet manifold on my 88 WR 250 is quite badly cracked although it still seems to run and tick over just fine. Any tips or advise or should I bite the bullet and replace it? Was thinking a damned good clean and sika flex.
sudco? whoever supplies mikuni's will have manifolds, I got one for the 400 easily
Agreed you don't have to have a Husky manifold, take some measurement & you can find plenty of aftermarket replacements..
Husky John
the inlet manifold is one piece on the water cooled 2 strokes from 84 to 87, after the 87 run was over they used a 2 piece intake, if you have the later one it is a Mikuni adapter if not you will need to get the part that covers the reeds and the part that mounts the carb
Uptite Racing made a 2 piece and you could also find a good one used and by the carb adapter from many places but they were Mikuni carb adapter pieces on the OEM
Here's Mikuni intake p/n list off Ebay if i remember right.
Genuine Mikuni carburetor flange adapter. For use when installing a spigot style carburetor to a bolt on application.
Sizing Chart: Dimensions are in millimeters.
Typically all sizes are available.
Sold Individually
Part Number
8.5MM Bolt Hole Center to Center
Carb Bore Size
Carb Spigot Diameter
Flange Throat Depth
Typical Carb Size
M-VM28-200K
60
30
35
28
26-28
990-842-046
57
30
37
23
26-28
990-842-007
75
34
40
32
30-34
M-VM34-200K
60
36
40
25
30-34
M-VM36-200K
70
40
43
25
36-40
I-VM38-200-1
75
40
43
28
36-40
M-VM40-200K
75
46
52
32
40-44
I-VM44-200-1
84
46
52
26
40-44
KHS-004
70-75
40
43
28
36-40
HS42/018-42K
70-75
42
45
25
42
HS42/062-42K
70-75
42
45
25
42
HS42/062-45K
70-75
45
48
25
45
HS42/018-45K
70-75
45
48
25
45
HS42/062-48K
70-78
48
51
25
48
