Information on Shift forks -
GaryM
I am inside my gearbox for 1981 430CR. I have a couple of later style
sets of 83 to 86 stronger/ thicker shift forks here. They are shorter
Always looking for the stronger or better solution.
Would they work without problems on this 1981/82 gear box set ??
Shifting gear like the 705 in this box look the same on later 500Cr set I have here.
But the other 388 (500) vs 714 (430) - well the beefier forks fits perfect on 388 its a better design has radius in slot of the gear really tight and supports the shift fork well - but it does not seem to fit on this older gear. Older shift forks does not to seem to have as much support like this even on standard gear.
I think I just answered my own question. I think No . Opinions ??
I have several piles of internal 430 parts. I've had good luck swapping around, but I'm not an expert on any particular forks. If there's something I can look at and/or photograph for you let me know!
The bigger forks don't work on the earlier gear sets. The radius of the fork slot in the gear is too small. It might work for a while then break something really important. You can use the intire gear set from the later model tranny. anything after the 1983's came out works great.
