In desperate need of a clutch hub!!!
babalu24
1999 TE 610 kickstart only anyone know where I can buy a used or new clutch hub just got one shipped from motoexotica but as you can see in the pic it's off by a mile any info would be appreciated
What's wrong with the current one, the notches from the plates?
If that's it, you can clean those up with a fine file and get some more life out of it.
It's the hub not basket when bike fell over gear shift went through cover broke two studs
Tell me about it all from getting knocked over since then modified the kickstand and repaired the clutch cover so close but yet so far away
The 02 250 is a different part number. I broke one of those fingers off of a hub before. To fix it I used a little bit of jb weld and I ran a countersunk screw in from the bottom with loctite. I ran it for years and never did replace the part. If you are concerned about balance put a screw in every finger.
I'm having machine shop put a plate and basically doing that while I got a beat up one from motoexotica bike is up n running
