I'm swapping temp sensor on TE310 x-lite..
Aaron8
..to updated Husq PN, before the superceeded one fails and strands me on the trail.
Is there coolant loss involved in the swap?
i did it without loosing coolant. I think there is a small enough hole that if you do it quick you loose almost no fluid.
What are the particulars on this. Old Part Number v. New. Do ALL 2012's need this or is this for 2011's or??
I plugged the vent overflow hose coming down front the rt radiator. I don't know if that helped or not but I didn't get enough coolant on the changeout to wet 1 napkin.
I had to replace it 3 times in a 100 hours of riding. Only a few drops of fluid comes out. On the last change I updated to the new part with the white shield vs black shield. Not sure which part comes with the 2012.
vacuum prevents too much loss (don't take the radiator cap off)
Mainly seems like a 2010 issue but many have had the issue, I am still using my original on my 09TE450 (going into my 4th season) so its somewhat random but probable
I don't think Dealers are selling "the bad ones" so if you order one you'll get a good one. I just have it in my pack for SOmeday- but don't think its failure would leave you stranded- just doesn't run as good.
