I have a 1996 wr360 and I'm trying to rebuild the engine please help
taywrh
I have a 1996 wr360 and I'm trying to rebuild the engine I have not been able to find any kits available. My cylinder seems savable and the rings as well only thing that seems off is the top end and lower in bearings. If someone knows of a kit out there that'll fit for this bike or maybe even just a diagram with exact bearing sizes so I can order them. Please and thank you! Especially helpful if someone's got an old box shoved in an attic of all the parts I need I will pay lmao!
As per this parts diagram :
Crank bearings: 6305 TN9 C4
You can also find any bearing size of the gearbox in case you need them. By top end bearing you mean the con rod small end needle bearing ? It is:
BEARING, NEEDLE 18X22X22 Con.road small end coupl.
Cheers.
Well on that I can not be sure 100% but they normally don't change big things like crankcases and bearing sizes, but maybe someone can confirm to be sure :D
