I.D. help needed
huskyborn
Need help to identify this air box and reed.
Airbox is for 1975 and most of 1976. For ML series frames. The carb adapter is for a later model when Husky coverted to Mikuni carbs, probably for a 1978 Unless the carb adapter itself is made of aluminum not magnesium and this carb adapter looks to be aluminum to me. Then in that case the carb adapter was part of a Mikuni carb swap kit that was available in August of 1977 to replace the Gurtner carbs on the 360WR's. The reed block was not part of that kit and used the original magnesium reed block. Hope this helps
Marty
I think Marty nailed it.
I finished rebuilding a 75 360CR a few months ago and the air cleaner cover on it was like this one, aluminum and free of castings for emblems and/or stickers, and had the Husky logo in the upper left hand corner.
As for the reed box, my 75 had the bing carb which had the male spigot and not the flange as this one has. Plus the reeds on the 75 didn't protrude from the box like on the later models such as the 79 390 that I parted out.
Kartwheel, you are correct in that 1975 was the first year of the ML frame but for the CR's only. The 74 MK frame WR's were carried over to 75 making 1975 a year that both the MK and ML frames were available.
