Husqvarna TE 510 2008 speedometer compatibility
Ismael Jesus
Hi guys,
Just broke my 2008 TE 510 speedometer.
Is it possible to replace it with a differente year one?
I can get good deals on used one from years 2006,2007 and 2009/2010.
Thank you.
...and they're pretty much bolt-on.
(the stud spacing is the same; the speed sensor connector is the same. I think this is true for the '08s also)
I think the stock husky ones are the same throughout the years. They may have changed it once? around '06.
Thank you ! That was very helpful !!
I think you mean this one, the TT VAPOR STEALTH COMPUTER:
https://www.amazon.com/Trail-Tech-7...coding=UTF8&psc=1&refRID=BEGAR6MVG0Z3F7F9JRPA
http://www.ebay.com/itm/Trail-Tech-...ash=item33c41f99ff:g:oPIAAOSwA3dYI8PX&vxp=mtr
or possibly the 08-12 Husqvarna specific model "752-102" :
http://www.ebay.com/itm/TRAIL-TECH-...m41a034796a:m:mN7b1WEY0RnvPe2WqZx6YEw&vxp=mtr
http://www.ebay.com/itm/Trail-Tech-Vapor-Computer-Kit-Stealth-752-102-/172343527661?fits=Make:Husqvarna&hash=item28207988ed:g:j6EAAOSwHsRYEX3g&vxp=mtr
combined with the suitable (universal?) DASHBOARD :
https://www.amazon.com/Trail-Tech-0...coding=UTF8&psc=1&refRID=QGCGVGTDF6VDA9EVZACR
http://www.ebay.com/itm/NEW-TRAIL-T...ash=item25b1072f51:g:niYAAOSwYHxWQiy5&vxp=mtr
or even a $180 BUNDLE with BOTH units like this :
https://www.amazon.com/Trail-Tech-752-102-Indicator-Dashboard/dp/B01A9Y6MRQ/ref=sr_1_cc_2?s=aps&ie=UTF8&qid=1491759457&vehicle=2007-629-19830-20-----13957------4-0&sr=1-2-catcorr&ymm=2007:husqvarna:te250&keywords=trail tech vapor stealth husqvarna
The last one does say explicitly "HUSQVARNA"... So I assume there is some level of better (plug?) compatibility ?
How did you guys deal with the connection, it would seem to me the simplest way is some sort of a "Husky to TT" wiring adapter, with one end that (almost) fits into the pre-existing Husky plug out of the bike, and a second one that fits right in the back of the TT unit(s).
Does something like that exists, or very close to it, it would be a cleaner install ? Link ? Or do you just wire "this red to this blue" etc. individually ?
Sorry for all the questions.
All the sensors come with the unit so they plug in with their own plugs. The lights you will have to wire yourself, no plugs. I think the only "husqvarna" specifics is the way stuff mounts not the plugs. Could be wrong. I always just get the generic kit and do what I want. If you want plug and play you will have to go with a OEM husqvarna unit.
I found the cheapest place for the trailtech was Thumpertalk store last time I bought one.
Herb and Ismael-
you could tap into the harness-end of the stock speedo's connector. Just put complementary pins/wire on the conductors you're interested in (hi beams, neutral, and turns, I'm guessing) and run them to the TT. secure the wires and fill the half of the connector with (silicone maybe?).
btw, turn sigs- you're gonna hafta "wire-or" them together. This isn't as hard as it sound: each turn wire gets a diode, and the cathode of the diodes are twisted together and have a wire soldered on 'em (this is the wire that goes to the single turn light or LED indicator). This keeps one direction of turn sigs from flashing the other at the same time.
yes, you could get a connector and wire it up to fit the stock husky connector- but for somebody without experience, this is a big job.
