Husqvarna Te 510 2005r Problem With Rear Brake
Sebaaa
Hi.
It's my first post here.
I have Husky Te 510 2005r. I rebuild the bike for supermoto and my rear brake Brembo is totally broken. I looking for repair kit for this brake but I can't find anywhere. Can I used kit (or brake caliper) from another bike? The piston has 30mm and 220mm the brake disc 220mm.
Thanks in advance. :)
Your bikes rear brake caliper should be part no. 800096939
The following bikes are using the same part numbers so they should be identical;
REAR BRAKE SYSTEM ( SM-TE 610 ) ( 2009 )
REAR BRAKE SYSTEM ( SM-TE 610IE ) ( 2007 )
REAR BRAKE SYSTEM ( SM-TE 610 ) ( 2008 )
REAR BRAKE SYSTEM ( TE-TC-SMR 250-400-450 ) ( 2004 )
REAR BRAKE SYSTEM ( WR-CR 125 ) ( 2004 )
REAR BRAKE SYSTEM ( SM-TE 630 ) ( 2011 )
REAR BRAKE SYSTEM ( 250-400-450-510 ) ( 2005 )
REAR BRAKE SYSTEM ( WR-CR 125 ) ( 2005 )
REAR BRAKE SYSTEM ( SM-TE 630 ) ( 2010 )
REAR BRAKE SYSTEM ( SMS-TE 610 ) ( 2006 )
A piston and seal kit is part. no 8000A0934
Piston only; 8000A2793
Seal kit only;8000A2794
