Husqvarna Te 310 R Starting Issues
Jona173
Hi!
Finally, my Husqvarna TE 310 R is running again. The fuel pump was broken and I had to test several ones as the original one costs almost 500€ (I am from Germany). Now there is another problem: I'm having starting issues, without the cold start lever, the bike won't start, at low speed the cold start lever is needed as well. The only thing I did before the fuel pump was replaced was getting a new temperature sensor, as I heard these often cause issues. As the temperature sensor was the only thing that was replaced other than the fuel pump, I suspect is has to do with this one. Is there anything that can go wrong replacing the temperature sensor (maybe there a possibility to calibrate it)? If you have other suggestions, please let me know.
Thanks in advance!
You might need to have your ecu re-tuned or reset. Also how long has your fuel been sitting in the tank. Bad fuel can cause the fuel filter or the fuel injector to clog.
