Husqvarna te 310 2011 infos
shark36
Where could I get the infos how strongly the screws have to be tighten (with torque wrench). 3 bolds which holds oil filter cover for example (this one I would need quickly). They are in and out quite frequently and I dont want to turn them around, since on my last bike it happened 2 times.... For some the infos are in maintenance book, not for all....
It's not in the manual on the USB stick?
For something like that, lacking torque specs, I'd tighten it moderately by hand (definitely avoid heavy torqueing) and if you're worried about it coming out, some blue loctite would fix that problem.
No infos on USB, no info on maintenance book..... Said but truth.... Thanks Glangston. But I would apreciate all infos. If somebody knows where I could get them, thank you in advance!
You need a workshop manual. It has detail service information. Go to you dealer it typically cost $15 or so. Significanly more detail than owners manual.
I have the the workshop manual and the torque listed for the oil filter cover screws is 6NM for the TE310 engine. If you can get your hands on a workshop manual do it, it has all the info needed and good pictures as well if you are not a confident mechanic.
Thanks! I'll try to get it somewhere. The link above unfortunatly doesn't work.
Turn until the bolt spins free. Remove bolt and stick toothpicks in hole with locktite. Reinsert bolt and tighten to 1fpt and pray all is well**************************************** Kidding. See above. I use locktite by the gallon. Expensive but it works awesome. Enjoy and ride safe.
