bultacosd
Hi, I own a 1970 360c 8-Speed Sportsman. I am running the lights directly off the magneto, however, they are incredibly dim compared to my Bultaco matador which uses the same set up. (The bike is also a little difficult start when hot) I went through the wiring carefully and checked the earth etc but there was no improvement. In desperation, I decided to check the strength of the magnets on the magneto and discovered that only one of the 4 was any good. (This check was done very crudely by seeing if each magnet would support a 17mm spanner)
However, the most unusual thing that I noticed is that the magneto magnets were North, South,South,South. I would have thought that they would have been North, South, North, South. The magneto is a Femsa Var 1-49. (Points and Condenser)
Does anyone know if this is the correct pole configuration for the magneto (N,S,S,S) or has one of the poles managed to reverse itself?
Or, do I actually have the correct magneto? It has "Made for Husqvarna by Femsa" stamped on it, and a direction arrow pointing in the clockwise direction.
If anyone knows the answer to these questions I will be truly amazed.
Many thanks
Jon
Many thanks
Jon
