Husqvarna 1981 - 1984 Swing Arm Service / Repair
hva-factory
CH Sponsor
When replacing the worn out Chain Tensioner Bracket (in-stock!), Use an 11m/m rod to set the gap from the inside of the arm and also rotate the bracket so that the bolt that goes through the spacer can be fitted with the nut on the inside (so the tensioner arm sits at the M6 Bolt - shoulder and not on it's thread).IMG_0317.JPGIMG_0322.JPG
