Husky TE 450 2010
kevin holden
Just bought the above bike and before i take her out i need to change the oils and check the valve clearances etc as i've not this before has anyone got any tips....
Thanks Guys
http://www.cafehusky.com/threads/how-to-check-valves-on-a-2006-4stroke-video.1159/
I think this is one of the best "how to's" on the net.
Removing the fuel hose from the fuel pump is the hardest part I think, of course yours is fuel injected and not carbed (the video shows the older carburetor based models). That and replacing the rocker arm retainer clip. Stuff a rag on the LH side of the valve chamber so your shim pads don't drop down into the crank case! A telescopic magnet tool is a must for removing the old shims.
As Coffee points out, make sure to measure between the rocker arm and the shim pad. Get the feeler gauge between the pad and rocker as flat as you can so the measurement is accurate.
Got it all done..... it's test ride time tomorrow i put castrol power 1 10W 50 oil in, replaced the coolant, check the valve clearance all ok, and just gave it a good clean. Thanks for the info
No worries, but you should really be thanking coffee.
Make sure to check the valve cover bolts after a quick ride. They seem to work loose from the standard torque.
