Husky rear spokes
R_Little
I need a few for a TE250 rear wheel.
I guess they are all the same.
Does husky sell them seperate of must I buy a set?
Thanks
make sure you WD 40 the spoke thread and nipples. Continue to do so every couple of rides. New spokes tend to stretch so keep an eye on tension.
If you relace a whole wheel once true and running every few rides go around the wheel tightening every third spoke about a third to half turn on the nipple. Repeat the process 3 times to cover all spokes. I start at the air valve count 3 spokes then tighten every third all the way around. Next I count 2 spokes out and then do every third spoke all the way arounf and finally I do the spoke next to the vale and off I go again. Works a treat.
