2008 Husky 510 SMR. So a couple of weeks ago I was riding and the bike just stalled out of nowhere. The bike was still on but when I press the starter button absolutely nothing happened. Took me a minute or two of trying and it finally fired up. Took it home and noticed the battery jumped out of it's holder and was laying on the air filter. Had made a 1/2" tear all the way through the air filter.
Was running fine after I fixed it and it happened again yesterday. Bike would stall when going up a curb or up stairs almost like you had to give it more gas than normal to keep it from stalling. Again it took a minute to get it going. Took it home and battery had jumped out again and tore filter this time it was about a 3/4" tear.
I am wondering what made it stall and what kept it from starting? Starved for air because the battery was blocking the filter, ran too hot, battery terminal becoming loose when bouncing up the stairs. If it was from overheating I'm wondering what damage could have been done if any. Bike starts and runs fine now but is there anything I should check? Also because there was a small tear in the filter I'm wondering if I should tear it down to see if dirt got in there. I was riding in the dirt for about 30 minutes but it wasn't too dusty. I removed the filter and there was no dirt in the airbox on the other side of the filter. If there is even a small tear wouldn't a lot of air and possibly dirt be sucked through there since it's the path of least resistance. Any advice would be appreciated.
