HSQ SMR 511 - O2 sensor problem
Luke87-SMR
HI guys, i'm new from Italy.
I bought smr 551 and want to remove O2 sensor.
I've already put on an Higashi pipe.
Took my smr to dealer who tell me that i can't remove O2 sensor.
He also told me that he put RACE map, but still FAIL message (without O2 sensor)
Now, if i remove O2 sensor, i must install some resistor on O2plug or not?
It seems strange that still appear FAIL message with RACE MAP.
Thanks
You need to put a jumper (piece of wire) in the jumper plug that is located near the ECU plug under the seat. That puts into 'race map 2' mode which then ignore the o2 sensor - then you can remove it without 'fail'.
