DrinkBeer;85230 said:So I have decide, finally, that I should lower the tall first gear of my '07 TE 450. How many should I add, one or two and will I need a new chain? Maybe not with one, but with two? Thank you in advance.
Jon
ghte;85440 said:I went up two teeth to the rear of my 06. I found I was stalling a lot on tight and steep ST stuff. It made a huge difference. However, I have since reverted back to the stock sprocket for the following reasons;
The bike has a pretty low first 3 gears
The engine freed up and just lugged a whole lot better.
It severly compromised the bike in other situations ie fire trail and occasional bitumen bits.
I will now stay with the stock situation as my riding is a mixed bag and the stock scenario is the best compromise. That said if you are fully specialised then a different gearing wil probably be better, just don't go too low/small up front.
JPinNC;100838 said:This thread is helpful as I have been pondering the same question for my '09 TXC250. I only ride off road, typical western North Carolina trails. Most of my riding is 2nd to 4th gear. On really tight, steep stuff, I feel like I need a little lower gearing (or more power from a 300 BB kit). So I have been debating a 51 vs. 52 rear sprocket. From the replies above, it doesn't sound like I will notice much if any change going to a 51. I will likely try a 52. Does anyone know how many links the stock chain has?
DrinkBeer;100988 said:I put a new chain on after going up two teeth in the rear. The stock was tight.
