How many of you have to use the hot start?
vtskier
My bike always requires the hot start to be pulled. Is there a way to tune it so that is not required? It is kind of pain when you stall on a hill or in a technical spot. Do tell...
Over the past 5 huskies I reckon the hot start button has been used twice only.
I put it down to the following:
quality radiator fluids
higher than oem rated radiator cap
flush radiator each year
iridium plug-cooler burning
dont run lean.
WOW, Maybe I need to make some changes! I use mine all the time, but I'd rather not have to. I have JD Jet kit and engine ice, stock otherwise. :confused:
The main reason my bike doesn't fire up right away is from not using the hot start circuit.
I ride my little SM450 around in SoCal traffic in the heat of the summer.
They put the thing on there for a reason. Rather, one pays to have it on their carb, so why wouldn't you use it if it's needed?
That might be a more interesting proposition....
I have used mine a few times over the years, mostly if I drop the machine on a warm day and it stalls and gets flooded. Otherwise, I never need to touch it.
