How hard is it to remove head on 2010 tc 250
Pedec
Sounds like I need to remove head to get new valve guides and rings any body have shop manual they want to sell or is it needed. I have done top end on 2 stroke but never done anything on 4 stroke other than check valves. Thanks for any input.
You have the take the cams out to change the shims and putting them back is the hard part.
If you can do that then you can R&R the head. Just a couple of bolts after the cams are out....if you even have to take the cams out to get to the bolts.
The cams are driven by a gear so that is great...maybe the cams can stay in.
Drain the cooland and unbolt.
Anyway, be very careful of the cam cap torque as the threads can stip out.
Motosportz how much oil does your tc250 burn and have you read my thread on how much my bike is burning. What do think my problem might be and if I need to rip it apart are there any thing extra I should do to get more hp. Like I have said many Times I really like bike but this needs fixing.
it is possible to replace the valve guides, one dealer told me that this will not work with these models that you need to replace the whole head.
