How do you connect spark plug wire to coil
brandontx
08 510 SMR
Ordering a new spark plug wire and cap. Does it just unscrew from coil? How do you connect the new one? Is there some sort of connector I would have to buy as well?
You can get a coil with the lead already attached. And that, to my mind is the best setup as it´s then watertight with only minimal loss. But mostly, the lead is screwed onto the coil and the plug cap. I always then seal the screw joints with silicon.
Tape over seam on both sparkplug cap/wire and wire/coil. The cap/wire seal failed on my 2008 and let water in to short out the plug.
