Hot start in gear with clutch
Biggziff
I find my 09 510 doesn't like to start in gear with the clutch pulled. This is hot start like if I stall it on a trail and need to get going again. If I pop it in neutral (clutch in or out) it fires right up, but in any gear it takes maybe 3-5 seconds before it'll fire and stay running. The clutch has little free play (MEM Clever Lever, but did it with the stock lever as well) I guess the clutch isn't fully disengaging but it seems like the adjustment is good...maybe bleed it? Could it be the O ring failure I've read a little about?
Not a terribly huge problem, but annoying.
Sounds like clutch drag to me. And it's a real "drag" if you have to find neutral in an uphill stall situation. I think that's always a difficulty w/hydraulic clutches. You can't just take up some cable for fine adjustments. Does your lever have a reach adjustment? If so,you may be able to adjust it a bit further from the bar to alleviate the problem
My 08 TXC250 clutch drags and causes it to be hard to start when in gear ... If I use true synthetic oil, it helps stop the clutch from dragging so much and the starting in gear is better ...
The bad o-ring issue causes the clutch lever to feel very weak and you'll start getting very little clutch dis-engagement ...
Thanks, guys. I may ask Steve at MEM to make me a longer plunger for the MEM lever to see if that would alleviate this. Might just be the nature of the beast.
I do have some adjustment, but it's adjusted now to give max disengagement when pulled.
I'm already running full synthetic oil
