hose to drain plug 2012 TXC310
msev1111
Anyone disconnect this and plug/remove it to avoid having to deal with it at oil change time? Any adverse impact?
Pls let me know.
The 310 has more air moving around the crank and creates more oil vapors than the 250 hence this return line. Some have vented it to the atmosphere through a filter without issues. (Robertaccio's TE310) Others have come up with different methods of connection to the drain plug. Most just get used to it - I have a dedicated nut driver for the drain line clamp - and after a few oil changes it's not that big a deal.
mine got butchered on first oil change when it bent trying to pull the whole thing out, then shot back in the bottom end of the motor when i popped it off the plug. So after a few hours i finally "fished" it out but its destroyed... im also trying to figure out if its alright to run the bike without it.
