High speed instability?
James Patton
I have noticed several people lamenting the stability at speeds over 60mph on the 449/511's.
I am a little obsessive about maintenance and the safety of my bike when riding. I checked my rim runout,
Steering head adjustment, tire pressures. Bumped the compression settings a couple of clicks and set out
For some higher speed straight line runs early the morning. The bike up to 85 plus can feel twitchy and
a little unstable if you grip bars to tight or letting weight pull back on bars as you are still accelerating.
If you are very far forward also. If you are sitting well back, relaxed, light hold on bars with some body
Weight on bars, bike seems fine. I did the same thing on a DRZ400S, it handled about the same (just takes
a lot longer to get going that fast) I think if the bike is set up properly they handle just fine, remember your
on the 255lb dirt bike with knobbies/rimlocks. Riding technique seems to be the most important aspect.
The more you ride them at speed, the less you notice any irregularities. A stabilizer may be a lot of help
for some. I always ran one on my old airhead BMW's and it was very helpful at 80 plus.
