High 4t engine temps...
Your engine is running hot and you question your current oil selection. You would...
  • Total voters
    11
Tinken
It’s a hot ass summer day; your engine is running hotter than normal. Radiators and coolant are fine, but you would like get the heat issue under control. You have been considering changing your lubrication to suit your engine's needs at this higher temperature.
Let's say your engine calls for 10w50, but your engine is running extremely hot (all other things are running normal). Do you run a higher grade oil, say 60w or do you run a thinner oil like 40w?
You would… :confused:
Niether...I would dump my emergency chloride additive in the oil :)
My roll up garage door was creaking so bad last night I thought it was going to break. Mixed stp with a chlorinated oil and oiled all bearings and hinges. Thing is silent now. Thats a lot of ddp, lol
Tinken, as you seem to be obsessed with oil related things (and thanks as there is a lot of info out there to digest) What is your take on Too2cool oil additive? This came on the scene in early 2000 and was supposed to lower engine oil temps drastically. I think Ty even promoted and sold it for a while. I tried it when running the then newer Rekluse autoclutch on my 04 TE450, seemed to work but I had my reservations. Thoughts?
http://www.two2cool.com/default.asp
This poll would mean its pop quiz time! Sadly I only managed 3 pages of your oil thread so I fail. I'll choose option B.
But you get an A+ recognizing that the answer is in that huge oil thread. Usually reading just chapters 1-4 is all that needed. If you were to ask the BMW Formula 1 engineers this question, you would get a laugh and then an explanation.
