Help, TXC 310r Oil Leak
I wish you were located closer to us. Course if you did, you'd end up spending a lot more money on other goodies...
I don't feel that this is a complicated job, but I wouldn't want you to drop the chain down.
I'd for sure be taking that one to the dealer for warranty. Who knows if it is something as simple as a bad o-ring, or something serious as a machining flaw in the bore that the shaft runs through?
It's probably a bad o-ring. I don't think the cams need to be removed if you can hold onto the sprocket and gear securely.
At that point might as well pull the head and send it to ZipTy for porting and the valve fix along with o-ring replacement. If anyone ever needed an excuse, there it be.
Well it's fixed!! Took it up to a dealer ( toy tech) and the mechanic Chris fixed me right up. Turns out it was exactly what I thought it was, the o-ring. The mechanic Chris had to take the head apart and pull the shaft out. The factory NEVER even put the o-ring on. It was completely missing. They put a new one on and the warranty covered it all. I got about two hours on her now and love how it handles. Big difference from my 09 kx250f. It was a little tight at first but I can already feel it loosening up. It was stalling quite a bit at first but I only stalled once today. Can't wait till it's fully broke in. I did the first oil change tonight. It was a little tricky with the rear plug and hose but got it done. Excited to get some more time on it.
Thanks for the help
Toy Tech is an awesome dealer ! .... I bought my TXC310r from them and had some stalling issues... Chris fixed me up with a richer injection mapping and it helped considerably !
