Congrats on your new 310R. As Turtlemoye mention, they do run significantly stronger as the motor loosens up a bit. Also, you didn't mention whether you or the dealer did the mods to convert it to "TXC" spec and load Map 3. Those will transform it from an EPA pleaser to a full-on race bike (with blinkers, brake and headlight).
However, even then, with the stock 40T rear it's woefully over geared. Hall's Cycles has some ridiculously low prices on the OEM Super Sprox's in various sizes for $29.99 (regularly $71.50). I bought a DID VT2 Narrow Enduro Racing X-Ring chain and have been experimenting with 47, 48 & 50T sprockets. 50T is standard on the TXC, but all of them will really wake it up off-road.
If you buy sockets or anything else from Hall's request the workshop manual on CD. They can hook you up.
Again, congrats and best of luck with your new Husky.
Nick, if your dealer can't or will not upgrade the ignition map Zip-TY certainly can - and since they're based in Oak Hills, CA too I expect the turnaround would be fast (perhaps you're within driving distance, if so even better).
The change in personality with the race map, emissions removal, and air filter change is truly something to behold. I can't think of another bike that for less than a couple hours work (going slowly) and about $200 in parts and programming (chain, sprocket, ECU) that you can virtually double its output and take it's already impressive rideability to a completely different level.
One word caution though, with these changes the stock throttle tube begins to function more like a ON/OFF switch - great for the MX track but not so much for tight woods or when negotiating difficult obstacles.
Fortunately G2 Ergonomics' Throttle Tamer with a 400 cam rectifies that problem by giving you a significantly more precision in ordering up the correct amount of power for the slow and medium speed stuff.
I could be wrong about the ignition module but is my understanding that our bikes, TE310R's, cannot simultaneously hold two different maps. If true that would make the map switch superfluous. However, even if a map switch were available I find that the bike runs so well with Map 3 I would stick with it and trust the throttle tamer to allow me to manually reduce power in greasey and other conditions when an abrupt hit is too much.
Anyway, certainly sounds like you're on the right track. I look forward to hearing your riding impressions when she's running at peak performance.
My buddy and I paid $5,300 OTD last month from a dealer in West Virginia. This was for a brand new 2014 txc 310r. Also got 20% off all parts for the bike.
