HELP stripped oil filter cap TC449
Cdn_rider
Ok so i do my first oil change on my Tc449( shops done it twice now, yes i know its easy ) and i strip the the cap/cover nut.. I didn't reef on it, the socket was on straight and bam its nice and rounded now what? no really how can i fix this? funny thing is i seen some nice red replacement ones off one of the vendors on here and i was thinking about blinging out the bike a bit. Guess im getting them now
Ive read on here this happing before i just can't find where IMG_1930.JPGIMG_1931.JPG
Tap it loose (hammer and screw driver if need be), tighten the same way. This trick should be usable once in emergency. Now get your self an aftermarket cap!
Husky special parts one from any dealer.
You should be able to get that off with a set of vice grips too.
The Husky accessory version uses a standard 12mm nut..no more rounding.
Another way to get more traction on the rounded one is to lay bike on side...then you can apply more pressure while you turn to get the stock cap off...this 1 time.
Ive read on here this happing before i just can't find where View attachment 27836View attachment 27837
I've had the same problem, use a rag in the socket to help take up the slack around the hex nut and it should work, worked for me.
