Help, start relay and charging system TE250 04
rcastro
Hi, presently having problems with start realy and voltage regulator. Have gone through hours of posts reading here with similar subjects and taken several notes. Feel that im becoming an expert! Anyhow, have not find at Owners´ and or Repair manual the section related to any electrical testing diagram and or resistance readings.
Can you send me a link and or teh pages realted to? Seems that wire colors are still the same with the newer models thus it would facilitate.
At attached wiring diagram there is a diode connecting ralay plugs at the starter but i cannot find any diode here. Is it inside the realy and is that in the wiring diagram just for information?
Many thaks for your halp in advance.
That diode is for surge suppression from the solenoid and will be integral to the solenoid. Even if it fails open the solenoid will still work.
What problem are you having exactly? No crank? No start?
Thank you, well, i understand that the solenoid should receive DC from the battery only but it is working as its been receiving AC currency! I placed a diode in the wire going to the handlebar and its working ok now. It was cranking even like that! I just want to understand how it works in order to be easier to trouble shooting in case needed.
