help !! spark plug cap issue
bigd
So after bringing my beast home the other day for the first time i thought id have a look at the plug cos i thought it was running rich.
I pulled off the spark plug cap and noticed about 5 or 6 little pebbles sitting in and around the plug!
i spent about an hour trying to flick them out with a piece of wire so they didnt fall into the cylinder !! .. (only then did i realise it would of been much easier to blow them out with an air compressor)
any way the picture says it all.
my spark plug cap doesnt sit far enough over the cap to stop debris getting in !!
is this a common problem or a serious design fault ??
any sugestions for a fix ???
oh by the way the cap is a ngk SD05EM and im using the standard CR8B plug
Yep same as mine, just keep the air hose close by before you remove the plug and give it a good "airing out".
