Help Needed! Any gurus out there?
thehaloera
My buddy (mechanic) and I haven't had much luck dealing with huskies service manual. I have had an ignition/charging issue that we are trying to trouble shoot. Bike is a 2007 510SMR
This is a message from my buddy:
"Found TPS out of spec on ohm reading in closed position. Also GPS off in 1st and 2nd gear. Pick up coil reading 100 ohms. Ignition coil is 0.4 ohms on primary. 10.8k on secondary. If you can talk or get on forums with this info, let me know what you can find. I did not find specs for reg/rectifier, condenser or pick up coil readings"
Any advice would be GREATLY appreciated. Original issue is that the bike dies while riding once it gets up to temp. won't start til it sits/cools for a bit, then dies shortly after once it start running again.
It been tooooo long since I've been able to ride my sumo. My riding buddies are wondering if something happened to me!
