help. I cant get my te511 oil filter out.
Freekman
Am I missing something. It will not come out no mater what I try. Tweezers gravity and fingers have all failed. It really feels like it is suctioned in or something. It will give a little but not come all the way out
Just take a pick or small screwdriver and tap a hole in it, the hook it and pull it out.
Tinken uses a drywall screw. No problem once you learn the drill.
I was about to, but I was scared of bannging to hard and messing something up thanks for quick respobse. All sorted now
I use external circlip pliers, there's just enough to grab onto within the indent of the filter to pull it out.
I use a little pen-type telescopic magnet. Find one with a small enough 'head', and it works wonders at getting any debris out of the oil screen and sump plug cavities too! :)
Yeah I just picked one of those up, figures it would be good to have have around
You can use a strong neodymium magnet to help pull the oem style filters out.
I no longer use the stock oil filters and use a reusable stainless steel filter which is much smaller in diameter. This filter is much easier to remove.
http://www.cafehusky.com/threads/oil-filters-for-the-449-511s.29284/
Easy to clean. Compared to a fleet truck extended filter, it wouldn't clean as well, but compared to a hiflo, pretty damn good and it's absolute, meaning 35 microns in one pass. The real filtration happens when we change the oil.
have you ever changed it, or does it pretty much last the life of the engine? How many miles you put on with one of them?
We ran one for 8,000 hard race miles on our KTM 525 and I run it now on my 511 and current 525. Should last the life of the bike.
