Help! 511 leaking fluids!
riz
A buddy's 511 is leaking what seems to be oil...anyone know why? And most importantly, how to fix it?
There's no cracks in the cases, no leaks in the gaskets...but this has been reocurring for the past few weeks. The bike is only about a month old btw
It's puking oil from your cases into the airbox, bad. There are several solutions for your friend.
1 : you can unhook the case breather from the airbox and run it to a catch can .
2 : you can get the ZipTy valve cover breather mod kit and puke more oil but it sends it bake to the engine.
3 : I made a special hose for the ZipTy mod and have the breather routed to my chain , i would run a catch can for SM with my setup for safety .
They puke more when they are new .
damn, so the whole "1 liter oil only" doesn't necessarily solve it, huh?
my friend will have looong nights ahead
thanks for the tip, Rearwheelin!
Running the engine with 1 liter doesn't solve it and creates problems down the road . There are many successfully running over 1300cc . Our bikes have a second clutch cald a torque limiter, it's designed to slip under xtreme conditions to "give" a little to break stress between the crank and tranny. Running oil levels low only makes the TL build more heat and when it goes out you can loose all drive. Not many have had this go out . The ZipTy mod directly addresses the torque limiter "TL " .
I have plenty of miles on mine using 1 liter, never any overflow or over heating. I have purchased ziptys system,
I think more oil a good thing, but you can surely ride the bike with a liter of 0/40 Mobil one in it, just change
It frequently.
If your buddy has never changed his oil ,he needs to. Might be gas in his oil from ring blow by during break in.
There seems to have been a glitch when starting this thread through my phone, and now there's 2 identical threads :/ sorry folks!
Anyways...he's running LESS THAN 1lt oil in it now and there's no more leak...he says the book recommends 750cc :excuseme:
if it's true that running so little oil can ruin the motor than he best go for a breather mod
thanks for the inputs, fellas!
PS: Rearwheelin, even if he was selling the passenger pegs, covering shipping cost from Indonesia to where you are won't be fun :)
