headlight problem
Jon
I have an 09 te 250, and the headlight is screwed up. it just stays on the dim/indicator setting. like when you turn the key on. then when i start the bike theheadlight never comes on. On the cluster the blue light saying my brights are on but it stays on no matter which way the switch is. Has anyone had this problem before and any ideas on what it could be.
ya because I was looking at more last night and found a connector. That if I move it around the light will come on. So im guessing its a loose wire or ground somewhere. Just havent got into it yet.
Connector may need a little crimping to keep it tight. There was a problem with that on other bikes a while ago. But yep, you are chasing a short for sure instead of a burnt bulb. Might check the bulb and socket to make sure it's all good.
