Headlight Help
RideLI631
For the past week my headlight was intermittently working coming on and off as it pleased. But now recently it stopped working all together. I checked the bulb it seems fine (i will double check) Is there a fuse that runs only the headlight? From what i know there is a fuse that runs the whole dash assembly and headlight on the same circuit but i could be mistaken. I was wondering if anyone knew where to look next or if they had a problem like this before. The headlight is not stock it is a baja designs headlight.
Check your fuses... Test the bulb plug for power when the bike is running. Originally- it wouldn't have been the same circuit as the dash.
I'd check the connection. They get pinched back there, and they're not watertight. Sounds like the crimping isn't solid.
