Headlight Bulb retainer clip
tonskiguy
2012 TE511, - I need a new headlight bulb retainer clip. I do not see it listed for sale. I do see the "Cover, Headlight" listed in the parts catalog ($85). Does anyone know if this includes the bulb retainer? Any chance someone has a clip laying around?
Thanks for the reply! I tried to look it up in the part catalog. I must have mis read it. Did you get one for the 450? Do you maybe have one? I could get a pic of the lamp housing to see if that looks the same.
Maybe its one of "those" things that you can't get. call a dealer. I used gorilla tape- works but obviously not OEM.;)
I have a stock 08 headlight. I will not be putting it back into my bezel because I run an 8 light LED. "IF" it's the same I "could" part with it if the clip is not available from dealer. Does Halls still provide the parts fiche? I'll look and brb.
EDIT: Not the same nor does it come separate. Going to have to prefab and make one there buddy!
I've got a headlight assembly on order from Hall's, they said it should come with the clip and bulb. What's another $85?:excuseme:
