headlight brake light on txc310r
Jon
What do I need to do in order to get a headlight and tail/break light to work on a 13txc310r. Besides the brake pressure switches? Thanks in advance
hey, you just gave me an idea ! my brake light went on permanently just over this last weekend, after a ride through some VERY heavily wooded areas: you might be having a similar problem: if you take off your mudguard, and/or the engine guard / sump guard, if there's ANY debris blocking anything, that could be the whole cause: I have YET to do this, on my own TE 310R, but I'm sure it's just an electo-mechanical inductor of some sort. something is NOT physically making contact, OR, it is, and it is causing it to be a permanent state, of either on or off. Hope that makes sense ! check it out. I suspect that (in my case) there's a small twig or something stuck somewhere that isn't all that conspicuous. check in, around, and under EVERYTHING in the path of that wire. Might sound like a lot, but you're gonna find the problem.
