bobnoxious67
Hey guys.
I'm changing out the fork seals (AGAIN) on my '09 TE450, and while I'm in there I would like to soften the compression valve shim stack a touch...like nearly everybody else on the planet I feel they are too harsh on the sharp hits like rocks and roots, deflecting the front end all over the place, especially when going up gnarly uphills. It's good in faster/hard hitting whoops and such.
Here is my stack. If you were going to remove a shim(s) and/or move some around, which ones? Is the one with the arrow called a "bleed shim"? Rumor that the harshness actually comes from not enough damping, and that removing this one helps...? I run my compression clickers all the way out, it's the only thing that makes them bearable.
