Handlebar Headache
arbo
Guy's recommendations please. I have a set of Touratech Bar Risers on my TE630, these risers are 24mm, approx. 1" but I still find them too low, I would like about another 1" higher again. I'm not super tall, 5'10" but just find my arms are fully locked when standing.
I've read through the other threads on this subject, not keen on the Rox Risers due to the way they work independently and could twist in an off. Can anyone reccomend a 2" riser or a high rise handlebar to overcome this. The oem bars appear to have a rise of around 120mm?
Thanks in advance.
I wouldn't be too concerned about the Rox risers twisting independently. Using the Husky side to side connected top clamp at bottom mount lessens that from happening. My bike has hit the ground many times without issue. Control perches and barkbusters move but bars stay straight and risers aligned.
Big plus for the low rise Rox risers is you won't have to mess with any cable lengthening or routing. Sounds like 1-3/4" would be enough rise for you also and don't forget the double axis fore/aft adjustment that other risers won't give you. Also the low rise are threaded on inside for attaching dual sport gadgets so if still concerned about twisting you could bolt a support between them.
http://www.powersportsuperstore.com/Rox-Speed-FX-Rox-1-3-4in-Pivoting-Handlebar-Riser-p/4722730.htm
_
_
Thanks for that, good to hear the Rox Risers dont move as i do ilke the flexibility in set up they offer. I may just reconsider.
I've always found the ergo's on our bikes to be a bit weird. If you are short enough to stand on the pegs with the stock bar height and your arm's not locked out I don't think you could even touch the ground to ride it in the first place.
I haven't changed the bar position on mine, but I'd like to. It is too low for standing. But, I am concerned about available cable length without having to reroute a bunch of stuff and make it look sloppy.
Well after Silverbullet's recommendation i've ordered a set of Rox Risers so i'll let you know how i get on.
+ 1 on the rox risers, they made a huge difference to my riding. I don't think they would work with the HDB system without alot of cable and hose routing.
You are correct, I am unable to touch the ground. I stop next to curbs whenever possible or stop with one leg down and the other sticking out. I am sure I look like a little kid.
