hammerhead brake tip on 610?
bensl
images
has anyone put a hammerhead brake tip on their 610. the stock one looks riveted on so surely you could just grind it off and drill out if necessary? something like this should fit or am i missing something?
i just have never seen the brake tip replaced so i am hesitant on ordering.
Is there space for the nut between case and lever? It's pretty tight on my 630. Perhaps you could remove the stud and use a machine screw with a button head from the case side.
That looks pretty nice, but I second what Ken said, very tight fit. Get some measurements on that tip from HH 1st
i just had a look and there appears to be room for the nut as long as the bolt doesnt protrude out any further. might require a little grinding off the end.
ill order one and see how it goes.
Just because it fits doesn't mean it won't stab a hole in your side case if you drop it hard enough... :excuseme:
The factory pedal will put a good ding in the case all by itself, just think what a bolt head would do.
The buttonhead idea may work though, or you could tap the brake arm and loctite in a bolt from the outside so nothing protrudes inward...
The brake is a great looking piece of bling, but I'm wondering if it really accomplishes anything except make the tip a bit larger. When folded it appears to project just as much as the stock tip, which has never been a problem for my boots to find. I guess that's what it is for. Just hold the edge of your boot tight to the bike and you can't miss!
Epoxy on a little chunk of aluminum sheet on the case to prevent that. A semi popular mod for stopping this issue.
