WbCherry
Brake disc guards are aluminum. The rotor is tempered steel, but slightly more expensive.
If an impact is bad enough to warrant the guard, wouldnt it jam the rotor anyway?
Do they promote brake fade (like the large front covers) or increase mud retention, leading to wet brakes? Or crud under the pads?
Guards under the bottoms of the front forks? Seriously?
Heel guards. When people are buying titanium axles and sprocket bolts...can't heel bumpers be replaced by that high-impact plastic sheet (Zydex or whatever) ? Or touch-up paint?
Radiator guards. They're a joke. My IMS tank actually protects better. The rad guards are just getting in the way of airflow, and threatening to rub through the tank.
Exhaust shrouds...no, just kidding. I'm not THAT stupid.
$300+ titanium footpegs. Really? Titanium's lighter than steel, but not stronger at the same weight....they need to be the same weight to be bend-resistant.
Carbon fiber case stckers?
The Touratech oil sight glass "guard". It's the same shape as stock! Just red! What?!
Saving weight with an aluminum sprocket....then using an aluminum fin for it? If one bends, won't the other?
Why not just buy steel?
Why don't they make quick-change rear sprockets, anyway?
Please discuss.
Oh, and while I'm complaining...why does the kickstand NOT have a wider foot (besides its other travesties)?
Doesn't the term "dirt bike" imply that you're not gonna park it on firm concrete?
And why is my nose bleeding?
Please discuss.
