kcumjc
I picked up my 2008 SMR510 last year in June and put around 1500 miles on it with no issues, aside from the occasional flame out at low revs. I'm hoping a JD Tuner will help that. I changed the oil as needed, checked the valves and cleaned the air filter. I also wiped out the air box, so it was clean.
My issue is, with the bike sitting this winter on a stand, oil is dripping from the airbox onto the top of the swingarm and running down it to the floor. This stuff isn't a simple wipe up kind of oil. I need to use cleaner. It is very sticky and green in color. The air filter was cleaned and relubed with No-toil stuff (red), so I know it's not that. It's almost like the stock airfilter oil, but I cannot see where it's coming from. I cleaned the airbox out when I reoiled the filter. It is dripping from the lower rear air intake slot.
Any clue? I haven't had the time to reopen up the airbox and check (two kids under 2) but I need too!
Thanks!
Thanks!
