Got my first husky need some advice 11 TE310 (power delivery/finding parts)
Fooschnickenz
Right now I have two issues with bike first is the bike is unridable under 10 MPH has 13/48 gears which I'm gonna change to 12/50 or 13/52 but I feel it's mostly due to the dead spot when throttle is opened slowly. From what I've read this a common characteristic of this bike in stock form. I'm pretty sure it has power up kit installed as 02 sensor is removed and only runs on race map. Now from what I've gathered this is something that can be corrected in a few ways one being a tuner and the other being a 12 txc ecu and injector. I don't care much about adding power just want a smoother delivery off idle so I can putt a around a bit more without wearing out my clutch hand. Which leads me to my second issue. Where do I buy these parts! Things I'm looking for but can't find someone who still make/sells them all websites seem outdated/out of order.
1: front and rear rotor guards
2: 12t counter sprocket (read lots about people ordering them but not fitting)
3: JD tuner
4: 12 ecu/injector txc
Any advice on this bike and getting it setup would be greatly appreciated. Also is this legend "George from uptite racing" still in the game? These forums make him sound like a god amongst husky owners.
Agreed, depending on your location either is a great way to go. You have indeed listed what seem to be the most popular mods. Some are quite happy with the injector TXC ECU combo and don't do the JD. Others do the JD alone. It really comes down to budget, but get it running the way you want before messing with the gearing, because you nailed the root cause of your displeasure.
You have to I-beat it and check the CO's and TPS.
The main question is whether your injector is yellow (4pt) or green (12pt)
If the injector is green the COs work around 100...if it is yellow the COs need to be higher like 105-110.
Also the TPS should be set to 102.3% @ WFO
BTW it is NOT mandatory to use the green injector. The yellow works okay when set up correctly. MY 2010 with a yellow injector will run clean all day while my 2012 with a green injector stalls from time to time.
I installed the JD tuner and set it to their recommended setting and it was definitely an improvement, but if I crack the throttle just off the stop the engine will kinda surge not quite pop but not run smooth. And when I open it up fast I feel the slightest hesitation. I may have to look into ibeat and making sure TPS is setup correctly. It's kinda making the bike tough to jump over logs cause I feel like I need to to rev it up too high to get the front wheel to lift in low speed situations. It will lunge instead of lift even with 13/52 gears. I dunno I kinda feel if the bike was running properly it could lift the front wheel in 1st with just the throttle and minimal clutch but maybe I'm just used to lighter bikes
I installed the tuner and ordered parts to make a Ibeat cable like eddycheckers the tuner makes the bike overall better but still will pop and stall sometimes if u blip throttle to lift front wheel. Is the TPS most likely the culprit and is the hardstop the adjustment?? And then zeroed in Ibeat
I couldn't find where to PM u but do you still have that my12 txc ecu?
I had a 2010 TE310. The bike barley ran!! I took it to George...and he made that dirt bike RIP...without the JD, and without the injectors...
Spoke with him on the phone the other day he gave me tons of awesome information about tuning this beast. I can't thank all u guys enough for helping!
