G450x triple clamps on a TE449
N4544D
Did a search, didn't see anything. Not sure if this is a really stupid question either given I am unfamiliar with compatibility between bikes as far as triples go, but....
Will G450x triple clamps work on the TE449?
I would like to open up the cockpit a bit more on the TE449 and it looks like the G450x uses dual bar mounting points like the KTMs. Goal is getting the bars forward, not necessarily up.
I have seen other suggestions (adapting enduro engineering kawasaki risers for up and forward) and of course using something like rox (which doesn't seem to be recommended).
Thanks for the help guys!
I dont know but would highly doubt it. The 449 has a standard husky type tripe and different forks.
Better to go with the Husqvarna hard parts triple clamps. The forks on the 450x's were 45mm too, not sure if they ever went to 48mm's.
Mate I can tell you the forks on the BMW 450 are very average and the clamp offset was quite peculiar to ride with. Not my cuppa tea old chap.
Before spending any money to get the bars forward, try removing the bars and rotating the lower bar mounts 180 degrees then re install the bars. This should give you some more room, if not, do what Tinken suggested and get the triple clamps from the special parts catalogue. I have them on my TC250 and there is a lot of adjustment in them, not just bar position but steering offset as well
