fuel
I get 120 to 130 km's out of a tank with the 40 tooth rear sprocket and around 95 km's with the 51 tooth sprocket on general trail riding hope this helps.
I get about the same in the dirt (with 50t on rear). Where do you live, should try and organise a ride?
I live Eastern suburbs and usually ride Toolangi area.
yep 80 ks is all i get to thought i would get more then that just fitted a jd tuner will see this weekend if it makes any difference.
gday robert i live at carrum mostly ride nerrim or erica and welshpoole havnt rode toolangi is that up yarraglen way
Victoria semms to have plenty of good places to ride to SA isnt the same I should try to get over there one day with my bike. Also sorry I have the 50 tooth rear as well not 51 but I am loking at getting a 47 just to see how that goes and will post the results when I have done it. I amalso close to finishing a mod to the oil drain plug/hose so I will post that as well when done which will be hopefully this weekend.
You are getting some pretty good economy over the 100 k's, I am running stock gearing 13 - 47 on a 2010 TE450 in power up mode and only getting 75 k's before the idiot light comes on
PS.. thats on 98 octane
the drain plug on these is a pain .im running 13 and 50 which im happy with but 80 kms is just a little short for the riding i do
Will be interesting to see how you mod the oil hose, I have some ideas, but would like to see how you did it?
Your right, Vic has LOTS of places to ride, best of all is the High Country.
