Padowan
What is the function of the non-return valve in the RH fuel tank vent?
Is it:
Currently my valve is set to allow air IN, which in the cold UK seems to be fine as it never gets hot enough to boil the fuel. However, when I take the bike to Spain, it gets very hot and therefore I find that the fuel system gets pressurised and inevitable fuel then leaks out of the cap.
Is it:
- To allow air IN, so that you don't pull negative pressure on the tank as you consume fuel, or
- To allow air OUT, so that you don't build up over pressure if the fuel heats up and expands?
