Fuel Pump Issues
brandontx
I have fixed my slipping fuel pump twice. The last time was about 4 months ago and after relocating the zip ty it was working perfectly for a couple months. It now is acting just like it did when the pump was slipping. When I have about .6 gallons left the bike will act like it is running out of gas when I get on the brakes. I checked the pump and this time is had not slipped from the base. Any thoughts on what it might be?
What bike year/model- what tank?
If it only happens when you are on the brakes from 60-0mph- maybe ist just from the fuel going to the front of the bike- I assume if that's the case the issue does not come up that much?
Maybe it is slipping in and out- and when you checked it it was "in". I wired mine- verticaly and horizontally- it has never moved. With my IMS 3gal on my 09TE450- I rarely get low enough to notice- But I have ran it totally dry without any noticable symptoms, once.
08 510 smr. Stock tank. I did it vertically and horizontally as well. After fixing it the second time it would run totally dry with no problems then after a couple months it started dying when on the brakes again so I know it can work properly. Maybe it is slipping in and out. I'll go back and check. It acts up every single time the bike gets down to .6 gallons.
